Moving tub and shower drain
Crookeddog
SOUTH CAROLINA
I am re-doing our master bath and took out the tub and want to make one big shower with 2 drains. The original shower drain and the tub drain.
I need to re route them but unsure how to do that correctly. I've added a couple of pics. Thank you for your help. The small red "dots" are where I want the shower drains to end up and the thicker red line is the big pipe that they both flow into. In the vertical picture, the space is just far enough away that the new trap won't get me there.
Tuttles Revenge
Assuming they were installed to code with those crazy long trap arms that don't appear to have any vents attached. You could simply add a 45 to the trap arm of the bottom photo and new trap to end up under that location and a Long sweep 90 to the trap arm of the top photo with a new 2" trap where it needs to be.
This video is to help locate the trap inlet for shower base in concrete, but I think the technique could be good on wood too.
Crookeddog
SOUTH CAROLINA
Thank you for your reply. This plumbing is original to house so I am also assuming to code. I am also assuming that it was vented properly because there have been no issues with that in the past. What it concerning me is that I am now changing this from a separate tub and shower that weren't used at the same time to a shower with two shower heads and drains that will be flowing water at the same time sometimes. But also not sure if that matters.
Tuttles Revenge
Both traps and their trap arms will now be 2" which is the correct size. All plumbing systems that are code compliant are designed for maximum usage. Meaning that even though its unlikely to occur, all systems should be able to be used at the same time without overloading the system.
