Hi folks,
Just found this site in the process of doing research on tankless systems. I looked through many posts and did not see one directly related to my situation.
We are considering a shower remodeling. We want to put is a shower with the side body sprayers and large rain type shower head. The design we are considering can use as much as 7 gallons a minute. We have a 40 gallon propane water heater. With a 40 gallon tank and 7 gallons a minute for a shower, we can see there may be a problem with running out of hot water during a long shower after a long hard day's work.
We are wondering what about a hybrid system with both the tank and tankless systems working together.
What if the flow system has the tankless system after the tank system?
Would it work as follows: the tankless system would not turn on until the water from the tank system started to fall below a certain value we set. We are thinking the tankless system would not be used a lot, but when it was needed it would come to the rescue.
What do you folks with experience with such matters think?
Thanks in advance for any help or comments.
