Minimum 'collar' for sweating pipe
jgold47
Detroit, MI
I'm working up a loop for a water filter and need to sweat copper joints between a bunch of different types of connections. Between each (Valve, Union, Male Thread) I've got a short piece of pipe to join the sections. Unfortunatley, I've got very little room to work with, so I need the copper lengths to be minimal. My question is how much 'collar' do I really need to sweat pipes between two fittings? 1/2" 1/4" less?
Cacher_Chick
Test, Don't Guess!
The problem I have run into is if sweating a valve or union, it will require more heat than can be applied to it before burning the flux or solder out of the adjacent lighter weight fitting.
You need the full "collar", and if you do the assembly correctly you can do it that way. A short "collar, or insert" is ALWAYS a weak joint and can separate at some future time. A good plumber does not have a problem soldering a valve next to a fitting and does NOT "burn" the flux doing it.
Dj2
California
Doing it correctly, as hj mentioned, is critical. Otherwise you are inviting future leaks. If you find it necessary to re-do all connections with new components - do so
