Mendota cast iron(alcove) tub install on slab floor
Sammy M
ca
I noticed on past discussions the need to install a ledger board for the tub when the floor was plywood. Is this still recommended for a slab floor installation?
Thanks a lot for the advice.
Normally the feet on a cast iron tub are a bit too high to touch the ground.
Kohler like shims.
I don't know how that is done with three closed in sides in a remodel. Perhaps in new construction you can do that.
Regardless, the instructions call for metal shims. Where do you get those in different thicknesses?
I've been installing with a ledger board. These tubs weigh over 300 pounds, and once they drop down, they pretty much stay down.
Kohler tubs typically have feet that rest on the ground, but a ledger board is just added security. It makes sure the tub moves with expansion and contraction of the wall structure.
Sammy M
ca
Thanks for the advice...the odd thing about the apron side, is that the cast iron is molded in such a fashion that you cannot run a full size 2x4 ledger board across the whole length against the wall. The tub strength is obviously engineered with a triangular support in the shaping to support which is right in the way of any ledger capability at the ends. I suppose I can still put a ledger in for the tub minus a foot at either end. Have you noticed this on the new Mendota...60x 32?.....thanks again for your thoughts.
