Devino
My father recently installed a Westinghouse 80 Gallon 5500w water heater. The following day when he was turning up the temperature on the thermostats he noticed plastic on the lower element and nylon on the attached wire was melted. This melting continued to get worse that morning until he turned off the power. I replaced that wire with a slightly larger #10 wire (imaged below) and the overheating has stopped. Everything seems to be working correctly now. Notice the discoloration on the thermostat temperature set screw and label. The wire got hot.
Here is the old wire and thermostat cover.
Has anyone seen a problem like this or know what could be the cause?
I have sent Westinghouse an email with these images and a description.
