StephK
Hi trusted members of this forum. Your help over the years has always been much appreciated! Got a floor heat question for you now.
We have installed PEX radiant heat suspended in the joists under the floor of our 1910 house. I did a ton of research before doing so and was told not to worry, the heat would eventually rise to the room ..... but .... after all this work, it's not quite working as planned. The furnace runs continuously to keep the room warm. I turned the mixing valve so the temp was high, and the floors/room eventually did heat up, it took 2 days, but to the tune of 170 water temp. I thought once it heated up, I could turn the water temp down to the recommended max of 120. But, when it comes back on, it runs continuously again. I'm worried there's just too much floor for the heat to get thru!
Here's the details:
Bathroom - subfloor + 5/8 plywood + durock + tile.
Hallway,closet,bedroom - subfloor + hardwood floors.
Used metal shield plates underneath
R19 insulation under that
My question is, how hot can I safely run the water to make this thing work? My boiler is kicking it out at 180 and I have a mixing valve that seem to be able to output at 170. I was worried about the hardwood floors and also the thinset and tile. But, by the time the heat gets to these layers, it's NOT 170.
Thoughts??
Here's the details:
Thoughts??
