Matching Toto Clayton with Memoirs suite
Taylor
Northern Joisey
Thanks to this great board, I'm going to chuck my Kohler Memoirs toilet. But I am committed to Memoirs bathtub and lavatory. So questions:
- It seems that the Clayton style matches that of Memoirs, can anyone with more experience comment on this?
- Does the Clayton Bone color match the Kohler Biscuit?
- The rough-in for the toilet drain is 14" from the wall (without drywall), any issues using the Unifit to get the correct 12-1/2" from unfinished wall?
Thanks again for a great board!
Taylor
Northern Joisey
Answering my own question, Terry's on-line store describes the Sedona Beige as Biscuit. Anyone have experience matching the Toto Beige with Kohler Biscuit?
Toto Clayton
They work well together.
I sell a lot of the Beige for bathrooms with the Kohler Biscuit.
Taylor
Northern Joisey
Bad news
the rough-in for the toilet drain is 14" from the wall (without drywall), any issues using the Unifit to get the correct 12-1/2" from unfinished wall?
Plumbing supply house tells me Unifit won't work with Clayton, only with toilets with the skirt. Bummer.
Any advice on whether I should worry about being out 13-1/2" (after DW) is appreciated. Not sure if would be overkill to bring out the wall behind the toilet by 1-1/2" (there is door behind on left, tub alcove on right).
In case you're wondering, rough-in was done by a reputable plumber.
I wouldn't move the rough-in.
Plumber may have moved it to miss a floor joist.
A little extra space behind will be fine.
If you want to pull the bowl back, something with a skirt and 14" will move it, but the 12" Clayton should be fine.
