Chrisdeli
Hi Everyone,
A quick question regarding well water pump cut in pressure. Would lowering the cut in pressure on a 40/60 pressure switch to say 35/60 or even 30/60 (if it can be adjusted that low) theoretically add life to the well pump? Reason being this would decrease the number of on/off cycles over the life of the pump thus sparing it some wear and tear (since the number of cycles is a main factor in a well pump's life)?
Also- Does a well water tank's air pressure theoretically increase in the summer? If I am measuring the air pressure of the water tank in the winter and the cut in pressure is 40 psi and I measure the tank pressure at 38 psi which is where it should be- will the air pressure noticeably increase during hotter weather so should I fill to say 37 psi in the winter to allow a ~1 psi increase in hotter weather? Hope this makes sense.
Thanks in advance,
Chris
Thanks in advance,
Chris
