ratkillingdog
Our drilled well is giving out and I am trying to baby it through the winter. Tests over the last few days shows it currently reliable for at least a quart per min. which will give us (2) people plenty to get by. I already had a 320 gal tank and a surface pump with a small bladder tank attached. Pump in the hole is connected to a pump saver and a 30 gal draw down bladder tank. I am thinking about valving from the submersible's bladder tank to the storage tank and setting the flow at 1 qt. per minute instead of higher volume and long rest. I don't have the proper electronics for the latter method. A float will be installed in the storage tank for full shutoff. Another reason for this method is the well seems to have a consistent flow, but a small reserve in the casing. Anything wrong with this method?
Thanks,
Bob
Thanks,
Bob
