ewarne02
We have recently been having problems with our above ground water pump. After trying to solve the problem myself, i eventually broke down and called a plumber. He said our pump was bad and he had it re-built for us. After having the pump rebuilt it ran great.
The problem we have now is that we have hardly any water pressure. And when we run a faucet or the shower, air pockets are mixed with water. When the air pockets come out, so does what looks like black sand.
We have a 30/50 shallow well pump. When the plumber re-installed the pump he never tested the water in the house. He simply put the motor back on and left. Now the pump turns on at 15psi and shuts off at 24psi. So here are my questions in short..
-Is the correct pressure being built by the pump? (on at15psi,off at 28psi)
-Where is the air coming from?
-What is the black sand that is coming out with the air?
-Should i have the plumber come back out and fix the problem
Thank You for anyone who helps, it is greatly appreciated!!
