pandtmoore
- Messages
- 2
- Reaction score
- 0
- Points
- 0
I have a shallow well Gould Jet Pump with a 15 to 20 gal. holding tank that says the pressure in the tank should be 2lbs less than the kick in pressure. 3to 4 yrs. Old. I am here 6 mo. and gone 6 mo. Last spring I left the pump on while I was gone. When I returned in Nov. I had no water. The next morning it just kicked in. Now when I flush I have almost no water pressure. Even when it pumps up and shuts off my pressure at the faucet seems less and with much less volume. I turned the screw on the spring pressure regulator but it didn’t change much. It is set at 55 psi. and 35 psi kick in. I tried to let air out of the holding tank but then when I opened a faucet I could here water noise coming from the holding tank so I added air. Tks. For any advice you can give.
Paul Moore
Paul Moore
