Load Bearing?
PugsDana
California
looking to take out part of wall. Is this load bearing? Vaulted ceilings.
Dj2
California
I'm looking at picture #3, but the insulation is hiding everything and the view is too limited.
Get a G.C to go up in the attic and look what's under the insulation.
IF the wall is parallel with the floor joists, and there's nothing underneath it, it can't be a load bearing wall. TO be load bearing, it must have a continuous path to a solid support - either sitting on a beam, or rim joist, or foundation. Note, I'm not a structural engineer, but a wall supported only by subflooring, cannot be structural.
PugsDana
California
IF the wall is parallel with the floor joists, and there's nothing underneath it, it can't be a load bearing wall. TO be load bearing, it must have a continuous path to a solid support - either sitting on a beam, or rim joist, or foundation. Note, I'm not a structural engineer, but a wall supported only by subflooring, cannot be structural.[/QU
Thank you for your reply. I should have mentioned concrete slab foundation.
PugsDana
California
Thank you for your reply. I should have mentioned concrete slab foundation. The duct that is running in photo 3 comes out on the same wall. It doesn't appear to have any structure attached.
"slab foundation" is immaterial, because we cannot tell what is below the floor. You have to determine HOW the ceiling joists are in relation to this wall.
PugsDana
California
I had a GC come out. He told me it was roof trusse construction so it's not load bearing. Does this sound right? Thank you.
