Leaky and whiny koher shower
Human being
336 (North carolina areas)
Yeah, My shower handle (Koher) Is whining and earlier it had trouble opening until i moved it a bit (Turning). Also my faucet has been leaking out water. WHAT IS HAPPENING???!!!!
royalflush001
Texas
There could be several possibilities :
1. Mineral buildup can be one of the most obvious reasons. Over time, mineral deposits can accumulate in your plumbing, causing reduced water flow and making it harder to turn the handle. The whining sound may be caused by water struggling to pass through these deposits.
2. The most common cause of leaky faucets are worn-out or damaged seals or O-rings. These components can degrade over time, causing water to leak from the faucet.
Call a professional plumber to inspect deeply and resolve the issue quickly.
new cartridges or servicing existing cant hurt to go new other than price it depends if they are old ones with washers you can often get years of service just renewing washers and lubing the moving parts. for some this is a simple job for others its not
