Kohler Tresham K-3950 toilet, Reviews, Pictures and Comments
Kohler has a new, "traditional look" toilet with WaterSense labeling.
The Tresham K-3950 with 1.28 GPF, with comfort height and elongated bowl.
I installed one in a 1920's Seattle home to see how it works and looks. The homeowners (Sue's sister) will be reporting back on how it's working for them.
http://terrylove.biz/home/48-kohler-tresham-toilet-k-3950.html
Front end view
Looking inside the tank of the Tresham.
The trapway of the Tresham
A few more pictures of the Kohler Tresham toilet
Looking at the underside of the Tresham bowl.
The bottom outlet of the Tresham flush valve.
Top of the bowl
With water in the bowl.
WJcandee
Wise One
New York, NY
Well, Terry, it looks very nice and very solid.
Just like my unuseable Portrait with the unconscionable Ingenium Flush did.
So...pray tell...how does it flush with its 2" canister and its non-dual-siphon trapway?
My own feeling is that Kohler makes some very beautiful china, but I have yet to encounter one that works as well as my Drake. And there is beauty in performance.
(EDIT: Don't mean to sound crabby; actually, I am curious what you think of the flush. Just anytime someone uses "Kohler" and "Toilet" together in a sentence, it's like tossing raw meat in front of a starving wolf. I will never shake off that Portrait experience, and I frankly resent Kohler for making a corporate decision to sell that thing when all they had to do was use it to know that it was total garbage. Shame on them. Accordingly, I will never install a Kohler toilet again, even if they gave me one for free. Because they don't deserve my business, especially when there are vendors who never wreaked that kind of havoc on unsuspecting consumers.)
I also think that the Traditional Look Soiree is much more aesthetically-pleasing.
Gusherb94
chicago/nw IN
www.youtube.com
The style of the toilet is interesting. I guess it's supposed to look "old" but it looks like someones modern take on an older style. (not really old at all), but that's beside the point. I wanna know how it flushes! Looking at the bowl design and shape of the trapway it couldn't be as bad as the "Ingenium" system used to be, that had a far more constricted trapway and tighter turns. This trapway shape looks good except for the tight turn at the exit on the bottom. and I wonder why they couldn't do a 3" flush valve?
Stuff doesn't like instantaneous changes in direction - it slows things down, and they can get caught. A 3" flush valve can release more water, faster than a 2" (obvious), but it is the overall design of the pathway(s) it follows that ultimately determines how well it flushes. Well, execution of the design makes a big difference, too. Toto is somewhat unique in the industry in that it uses a much drier clay mixture when forming a toilet. This creates greater consistency in sample to sample, and reduces slump, twist, and other distortions as it dries. A good design where the pathways have distorted doesn't work well. Why Kohler thinks things will turn a sharp 90 well, I don't know. Maybe they went to a different school than I.
stephenk
Plains
Even though it's a new model, this toilet is listed on the MaP website. It has a 1000g map rating.
The Kohler website says it has a 2-1/8" trapway, but it doesn't mention the flush valve size.
Link to Tresham toilet on Kohler website.
Edit - there's a video at that link. This toilet uses the Class Five flushing system, which claims to use a 3-1/4" flush valve. From looking at the parts diagram, I gather it's a flush-tower style design, not the traditional flapper design.
Wptski
Retired Machine Repairman
Warren, MI
A 3 1/4" flush valve with 2" opening as shown above??
stephenk
Plains
Yes, it appears that way. Just because the flush valve is a certain diameter that doesn't mean the opening on the bottom of the tank has to be the same diameter.
Kohler appears to use a design on some of their toilets where the opening of the flush valve is larger than the opening on the bottom of the tank. I think the theory may be that it helps increase the water velocity.
Anyway, here's a video of a different Kohler flushing system. The class 5 videos I found don't talk about the flush valve.
Here are a couple images from the video.
When Jamie and I had lunch with David Kohler and their head engineer, several years ago, the original Class Five was coming out, with a 3-1/4" flapper. I mentioned to them that it may be better to have a less then 3" flush valve. That even though it had been 2" for 100 years, and we were now seeing 3" valves from TOTO, that it may be time to play around with the concept and dial it in somewhere between the two sizes. At that luncheon meeting, he wasn't thinking about downsizing, but about his new marketing campaign about having the "biggest".
We disagreed on that. I'm all about what works long term. I told him if it was only about having the biggest, that someone could always bring out a "bigger" one, not necessarily a better one. It wasn't long before American Standard came out with the Champion "4". Which when you measure the outlet of that one, it's 3".
The original 3-1/4" flapper of the class five has now been replaced by the canister flush. I guess it was too big. But kudos to Kohler for making the change.
I put a tape on the outlet of the Tresham tank, just to show what the current sizing is. It's less then 2", more like 1-3/4"
The bowl seems to work, so installing the bowl at a friends home, which I visit sometimes, lets me get some "in home" reports on how it's working.
I will bug them to report back on it. I will say this, it's better then the toilet I pulled out.
FWIW, the media used to flush in the MAP testing is plastic wrapped paste...not exactly like the 'real' stuff. It's a lot easier to make more flush and not get caught up in the internals of a toilet than the irregular, not smooth surfaced real stuff. Manufacturers have figured out how to make their toilet look good on those tests...that doesn't mean it will really work great in the real world. Anything 500 or above is more than adequate for 99% of the people out there. Totos work well with the 'real' stuff.
WJcandee
Wise One
New York, NY
Hey, Jim, you're the engineer in the bunch.
It's my impression that the "funnel" of the Champion and of this thing doesn't do anything to increase the water pressure at the bowl when flushed, that the weight of the water would produce essentially-similar effects whether there was an opening at the bottom of the tank with or without a funnel. (Indeed, I can see how the funnel would eliminate pressure from the side.) However, I never took a fluid dynamics class, and I know that the engineering wrt fluids is complex and sometimes counterintuitive, so...
what do you think about funnels immersed in a tank?
(PS I recognize that there may be a Venturi effect, something I learned about when wondering why the wind velocity was so much higher in the park between my old apartment towers in Chicago as compared to the wind velocity on the street. However, it seems to me that the velocity increase has no relevance to the flush in the bowl below, particularly because IIRC there's some kind of conservation at work (i.e. pressure drops and velocity increases), and I think it would probably exist regardless of the funnel at the opening. But again, I know when I don't know about stuff.)
A venturi only speeds things up for a short distance...may be enough, in this instance, but it's hard to say.
WJcandee
Wise One
New York, NY
I didn't mean to distract with the Venturi thing...I thought it was just an element of useless knowledge that I could use to show how little I actually know.
I'm wondering more whether the funnel does anything meaningful other than provide a marketing gimmick: "We have a 4" valve!!!"
West Seattle
Seattle
Hey Terry
Brian and I wanted to thank you again for the wonderful new toilet!!! We really do love it! Not only does it look fantastic in our home, but we are marveling at how little water it uses – and that really speaks to Brian’s desire to be efficient in all that we do here at the house.
C
GoKohlerGo
Brand New Plumber
Michigan
They actually do have 3" flush valves. 3 1/2", to be exact. And I actually hate Toto, Kohlers are better. Sorry this is such a late reply, but Kohler has better bowl wash sometimes. The Drake doesn't swirl at all, neither does the Class 5 but the Class 6 is much better. I guarantee my Kohler would do better in a bowl wash test than the Drake. Again, it is a Class 6 so the bowl wash is much better.
My issue with Kohler is parts availability...and, while some people never have problems with their toilets, if you simply look at the trapway design, you'll see that on many of them, the outlet makes a sharp 90-degree turn at the flange and the Toto designs make a much more gradual turning there. Depending on the size, shape, and hardness of the waste, things just go down the Toto toilet's trapway faster and with fewer problems. Some never have a problem, others have problems on a regular basis with the Kohler design. Things do not make 90-degree turns and maintain decent velocity unless done properly.
I do not ever remember Terry saying Kohler had anywhere near that level of defects. I do remember him saying that Toto has the lowest of the MANY brands he sells. The 20% figure I remember was about his breakage factor and the reason why he no longer ships toilets, and limits his delivery area.
My last experience with Kohler was on a special order. Each time the supplier called Kohler, they said it would be shipped tomorrow. This went on for MONTHS. IN a week or so when it didn't show up, they called again, and got the same story...it will be shipped tomorrow. Then, they sent the wrong thing. THen, once I got it, I was not particularly impressed...parts fit, paint, fit and finish. At that point, I didn't want to send it back and suffer the same, horrible customer service I got again. Since then (this is a shower door), the paint chips, the bearings are crappy and make noises, and even with the several holes, the system did not have a proper position to adjust the height in the track well. The holes in the glass were all rough. If you know anything about glass, you want a nice clean hole. It hasn't spontaneously shattered, but it should never have made it out of the factory, in my view. So much for quality control.
I do like some of the designs, but from an installer's viewpoint, some of their stuff is HORRIBLE, and almost unreasonable. For example, they have some shower body sprays whose rough-in must be less than 1/16" accuracy to fit properly in the tile. Do you know how hard that is to do when trying to get multiple trades to communicate? This is the only company I know of that deems it reasonable to set such strict requirements. They design in a vacuum, and not for practical use. Then, if you search this forum, you'll find stories of Kohler bending over backward to help people, then you'll find others where they say, sorry, you'll just have to replace the thing...we won't help you. So much for a decent, stable design and continued availability of replacement parts. Few places carry Kohler replacement parts since their design changes so often, the inventory would be HUGE, with no expectation of ever recovering the investment. So, do you want to wait a week or more when you need a part? If you do, buy Kohler. My personal opinion and experience.
I took this picture in Kohler Wisonsin some time ago.
The flush valve that goes in these things. Just so you know, I'm six foot one, and Brian, the guy with the tie is way taller than that.
A funny story
One day my son and I were having lunch with David Kohler at The Keg in Bellevue and we were discussing flush valves on toilets. Kohler had just come out with their Class 5 flush valve with the 3-1/4" flapper. On my website I had mentioned TOTO's Class 4 performance. Kohler now had their advertised Class 5. I suggested that from a plumbers standpoint, that if the performance was fine with say less then 3" and the seal could be stiffened up, then it would be more durable. A part that lasts longer is always a good thing. About two years after that conversation, they came out with the Aqua Piston that he's holding above.
