Kohler or sterling shower no hot water
Barry1978
Michigan
My shower recently stopped getting hot. I have tried to adjust the hot water from the valve or handle with no luck. I have an older type kohler single handle shower. I replaced the mixing valve and still no hot water. I took the shower head off and I have hot water coming out but as soon as I put it back on the hot water stops
WorthFlorida
6th clinical trail chemotherapy 5/15/24
Solutions
Orlando, Florida
Where is the hot/cold water shut off for the shower? Do you know if your valve body has stops or a shut off perhaps in the basement? With the water off and the mixing valve removed, turn on the hot water to see of water flows to the valve body.
WorthFlorida
Solutions
Orlando, Florida
Did this confuse anyone else?
I think it is an old valve seat or other obstruction closes off the water flow. Without a shower head there is little resistance and the obstruction moves, slow up the water flow and the obstruction closes.
Another is the balancing spool inside the mixing valve but it was replaced.
Barry1978
Michigan
So what would be the best way to clear the obstruction
Marlinman
Jacksonville Florida
Look for this with the gray cartridge removed. If you see black plastic this needs to be changed. If you see only brass additional troubleshooting will need to be done.
