Kohler K2975KSNA Master Shower Thermostatic Valve
MrJOAT
Iowa
The instruction for the valve state "The lower port of the thermostatic mixer is intended for use with a bath spout only. If a bath spout is not used with this product, the lower port must be plugged." My shower design has for functions (3 body sprays, shower head, wand, and rain shower head). Each with a separate volume control. Has anybody come off the bottom port of this valve to a volume control then to a shower function instead of caping it and taking all four functions off the top port?
TJRAD
California
Your Kohler 2975-na valve is a Thermostatic valve only that requires seperate shut off valve to turn the water on and off. You can use both top and bottom outlet ports to feed your separate volume controls.
So yes you can use the bottom port in addition to the top port for your installation.
Good Luck.
MrJOAT
Iowa
Good Luck.
Appreciate the assistance!
