SilentNoise
Hi there. First time poster.
I moved to my acreage almost 4 years ago. It's got a 44' deep x 20" diameter bored well with roughly 10' of lift above water level before the line goes through the casing and runs underground to the pump shed. I'm running a 3/4hp convertible jet pump in a single line configuration, just as the previous owners have run for years. Since buying the place, I've added a spin-down sediment filter, a couple of big blue micron filters, and replaced the pressure tank. I can see that I'm pulling practically no sediment and the over all water quality is great besides being a touch on the hard side.
With all that said, the pump has been losing it's prime on occasion since late August - it's nothing consistent, but obviously enough to be absolutely maddening at this point. I've gone over all of my lines, valves, fittings and clamps at this point, and all are good - I can't see anything leaking or even hear anything hissing anywhere. The only thing I haven't been able to look at is the foot valve, so I wanted to see if anyone had any ideas:
I can't get the foot valve because when they put the line through the well casing, they stupidly used a bulkhead, 90-degree elbow and barb to attach the down tube rather than a pitless adapter, and it's about 8ft below ground level to avoid freezing, so there's no reaching it by hand (and I don't think my 8-year-old nephew - or my sister for that matter - would be too keen on winching him down the well to see if he can disconnect the down tube from the fitting. LOL).
Any ideas?
Any ideas?
