Kurt Kreassig
Recently purchased house built in 1980 and crawl has two shallow well pumps but I cannot understand the configuration.
1. Each shallow well pump was connected to a separate 2" well line
2. Pump 1 had a 1" line labeled supply running behind the wall
3. Pump 2 had a 1" line labeled Ret/Dis running behind the wall and this line was also connected to what appears to be a 1" well line in the ground.
4. Both pumps set up as shallow well pumps
- One pump was deteriorated along with pressure tank- I keep it but is needs work and it is disconnected and I capped the 2" well pipe it was connected to.
- The other 1 hp pump - I set up as shallow well pump connected to 2" well line. I get some water - but sporadic and difficulty holding prime (not using tank). PVC seals are tight.
My question is - the smaller 1" line that is sunk next to the two 2" well lines.......is that actually for a deep water well set up? Currently it is not connect to anything now - but is was connected to the broken pump at one time.
So the bottom line - coming up from the sand in my crawl - I have two 2" well lines and one 1" line all right next to each other.....what's the set needed if I only want 1 pump for irrigation?
Any help is appreciated.
Kurt
Kurt
