Well: 120ft deep with 1/2 horse pump
Softener: new FLECK 5600SXT ERADICATOR 3000 ON-DEMAND WATER SOFTENER/FILTER = high capacity fine mesh resin, .25 ft3 gravel bed, KDF 85 MEDIA GUARD, 64,000 grain, 5600SXT ON-DEMAND CONTROL VALVE can be seen at apluswater.net
Before I replaced my previous softener with the one above, I had my water tested by two local softener places with readings of 20 and 29 gpg of hardness and 2.5 and 3 ppm iron. We are a family of 5.
When I replaced the old softener (it was undersized) I noticed iron build up in the incoming pipe to the softener, maybe 1/8inch layer. I believe this represents a 30% reduction in pipe size.
The new softener does effectively remove the hardness and the iron. The problem I have is that after regeneration, I need to run a faucet close to the softener for about 5 minutes in order to to "flush" out iron that has been "liberated" but remains in the softener. Once the water runs clear, all is well until the next regeneration cycle.
I tried increasing the backwash time from 10 to 15 minutes and the quick-rinse time from 10-15 minutes, but this has not solved the problem. The Fleck indicates a flow rate of 4.5 to 5.5 gpm with a bunch of fixtures open (basically a trickle at this point). Putting the softener in bypass does not appreciably increase the flow. My fear is that my pump is undersized and can't generate enough flow for proper backwashing.
Here are the options I've come up with (generally cheapest to most expensive):
1) Replace 3/4 inch CPCV from pressure tank to softener
2) Replace 3/4 inch CPCV from pressure tank to softener with 1inch CPVC
3) Replace the pump with a bigger one.
Any other thoughts or comments would be appreciated.
David
David
