CuttyOX
Hi,
I have a Navien NPE-240A tankless water heater that is connected to an external hot water recirculation system that goes to my hydronic radiant floor system.
Last week my hot water was not staying hot, if I hadn't used the water it would get hot for about 30 seconds and then get luke warm/cold. I thought it could be an issue with my Navien so I cleaned the filters and flushed the system out with vinegar and then with flow-aid the 2nd time since vinegar didnt work. The issue wasn't fixed and after doing some digging I had a feeling it may be a crossover issue because water was still coming out of my bathroom sink and shower when I had the faucets turned to hot before I drained the system and the hot water line off.
I turned the valve off to my external recirculation pump and now I get hot water at every fixture.... Hot water is working fine now but I won't be able to heat my basement floors with the system off.
Had two plumbers come out earlier today to give an estimate. 1st one wasn't sure and thought I need to get a hydronic expert out, 2nd one confirmed my findings and that cold water seems to be mixing with the hot water pipes which is why my hot water won't stay hot.
He thinks it could be that I need an additional check valve but waiting for him to talk with some colleagues and get back to me. I asked why this would have worked in the past (since the house was built in 2014) and not have ran into this issue previously and he couldn't tell me but thinks adding this additional check valve will help.
Any thoughts on what could have failed? Would like to figure out the issue without installing an additional check valve if possible
