Mikesm
Hi everyone... We're building a big house for our large family- 9000 sq ft, with 3 dishwashers, 6 showers, and 3 sets of laundry, and everyone loves having their hot water when they want it. The house is plumbed with a recirculating hot water system, but no radiant heat as that doesn't make a lot of sense here in the mild climate of the SF Bay Area.
While our plumber does great reliable work, he's very much old school, and has never installed a unit with a stainless steel tank. While we have a whole house water filter installed, no one is comfortable going with a tankless set of units, but I want a very efficient DHW system, since energy prices here in PG&E land are crazy high. And I want a very reliable system, and one that needs less maintenance because of the busy family life we all get to enjoy.
Based on research, I think going with a stainless steel tank based unit or units would be great on the upkeep side - no anode rods to deal with, and the HTP units seem to have great reviews for efficiency and performance. So I'd like to go that route even though the plumber would like to stay with the usual Rheem or AO Smith units, and a pair of 80 gallon ones.
I am trying to find a system with strong FHR ratings, and good recovery GPH. The plumber doesn't really do the math, so that's partly why I'm asking you all for help!
We could go with a big Phoenix unit, like the PH199-119 - very strong performance, with good insulation so it doesn't lose a lot of heat when idle, but plenty of recovery heat performance. But these units seem to be very expensive ($7000) and not very available locally.
Home depot carries the Westinghouse version of the Pheonix LD line, and the PH76-80 has very good performance with a 206 gal FHR, but I am not sure it would be enough if everyone was active at once. But they are much less expensive, and I could go with two of them. Would that be overkill though?
I have room for both, but is the insulation for the LD line the same as the big brother version? I worry about all that hot water sitting around losing heat at night when everyone is at work and school, and we have the usual housework going on at home.
The other option would be to use a couple of the new 100K BTU Crossover floor units, with 130 gal FHR ratings, but the ability to keep going, and and they are a lot cheaper than the LD units, and I would not worry so much about the smaller 20 gal tank losing heat through the day and night.
But these units are very new, and not a lot of reviews that I can find. Have folks here used them? Do they have modulating burners like the more traditional HTP models?
And is it OK to go with the Westinghouse version instead of the HTP version? Are they really the same unit?They are much easier to get here.
And if we go with two units, they would need to be piped in parallel right? Anything special to watch out for with these units that we should keep in mind?
Thank you all very much!
Thx
mike
Thx
mike
