Martina
Hello, everyone! I am currently in the process of remodeling our master bath and ran into a plumbing issue. I plan on using the Schluter shower pan with Kerdi drain. After doing the demo and exposing the drain pipe, it appears that it may be slightly too short for the Kerdi drain to connect. We're talking about 1/2" or so. I'd normally just add a PVC coupler and additional piping, however, that is not a possibility in our case as it would raise the pipe too much. I did an online search and came across pipe extenders and inside connectors (see attached image), which I think may be a good option, but I was wondering if I would be violating plumbing code, because those fittings will reduce the water flow in the drain. We currently have a 2" riser pipe coming out of the ground (see image # 2). Thanks in advance for any forthcoming responses in trying to get this issue resolved.
