Questions1
I don't know if the heat in my room is controlled by the condo association. I use window AC to cool in summer.I am in a 2 bedroom condo and the heat is the baseboard heat. When I lived in a rented multi unit apartment , the heat is run by the building manager and janitor so we have no control of the heat. In my condo living room wall, I see a thermostat (Thermostat is white-Rodgers 156-0399G) on the wall near my living room door. I moved the level underneath to right to increase the number but the heat I have in my living room doesn't change. I am getting some heat but I want bit more heat as it is getting colder by the day. . Pls tell me how do I increase the heat in my room? My bedrooms also have the baseboards but I can't find any thermostat there so how do I increase the heat in my bedrooms? Thank you
So, how do I control, what do I have to do to increase the heat in my living room and also my bedrooms? The thermostat is only in living room.
If the old thermostat doesn't work, how much would it cost to replace it with a newer one, cost, and install charge?
If the heat is controlled by the association, then playing with the current thermostat or replacing with new one won't help right?
