Actually I think part of the leaking problems I've had was because of the crap LD valves that have "out-of-spec" threads (right?)...
I've got one LD valve that has one socket so bad that... the fitting skips a few threads, just goes past them when inserting, so then it hits threads when there are only a few threads to go before it bottoms in... and the fitting is so loose all the way to the bottom... the other LD valve isnt much better... no wonder they kept leaking.
So finally I got a Mueller valve, screwed it in without even adding more tape, and no leaks at all!
I thought LD (Taiwan) was good but apparently they suck, the Mueller (China) is better.
