Steve Harris
When I hooked up my outdoor shower this spring there was no water coming through the valve (a Symmons Temptrol -- appears to be a S242-Body). I removed the unit, took it home and disassembled it. I removed the cartridge (TA-10 "Control Spindle Assy") -- it looks to me like (a) the cold water enters the cartridge from the front, (b) the hot from the back, and (c) the mixed water exits from the center on its way to the diverter/volume-control and then the shower. Twisting the spindle moves the cartridge back and forth, allowing more hot and less cold (or vice-versa) to pass through the cartridge.
The cartridge is a cylinder with a bunch of holes (to allow the water in at the ends and out at the middle), and there is a piston (?) inside the cartridge that slides up and down (back and forth?) when I shake it. I found a DIY video where the guy showed how to free up a stuck piston -- implying that the piston must be free to move and, once freed-up, the old cartridge could be reused.
I assume the piston must have something to do with the "Temperature-Pressure Balancing" function of the Symmons mixing valve, but I don't understand just what it does / how it works. Can anybody enlighten me?
Links:
Links:
