worrywell
I will like to let all those that helped me that I opened the wall to inspect the problem. No pipes were leaking.There was moisture inbetween the shower cavity of the shower stalls. The moisture was located on the bottom. The problem is the water is leaking through the grout and tile and into the walls and shower pan to the first ceiling. The greenboard will be removed and Durlock cement boards will be installed and waterproofed with Redgard and retiled and regrouted. This should solve water from penerating to the shower pan and walls.
Do you agree that installing the durlock boards all around the shower stall, waterproof and retile/regrout will correct the water from penerating through the grout and tile?
Thanks all,
Thanks all,
