I have not found good hose clamps at the local HD and Lowes. The ones there are weak. I will be placing a pump 480 feet down with poly. What recomendations or tips for the connections?
I have seen mention of extended length barb fittings. Where (Home cheapo?) do you get them?
What are the pros and cons of torque arrestors?
I was thinking of using 500 feet of cable to lower the pump with a winch instead of hand lowering. The cable would then be used if we needed to raise the pump later if necessary. Any thoughts?
Thanks.
kent
Thanks.
kent
