Hello! I have recently installed a new water softener and and the installer had to replace the controller because of a faulty touchscreen. The problem I have is that I had two different technicians that actually input two different and very different settings for my system and I am a bit confused now as to what settings are the right ones. I’m particularly concerned with the draw and rapid rinse times which seem to be off by what most people recommend in this forum (that said my knowledge about softener is very limited so I was hoping to get some help)
My hardness is 25 gpG and on the green sticker near the injector it says .12 GPM and 37 lbs salt min. We are two people in the house.
The rest of the settings can be seen as they come in the controller interface in the posted pictures, as well as a photo of the injector.
The softener is up flow and dual media filter (suspect activated carbon filter) and the brochure can be found here, which will hopefully be helpful in this case.
I would be very grateful if somebody could take a look at those settings and maybe make recommendations. Thanks so much in advance!
