TURBOSCHILZ
Hey fellas, I'm new to the site and have an issue that I could REALLY use some help with. I've recently purchased a home and it has an older sprinkler system, probably 80's I'm guessing. I've gotten the system into 100% working order, the only problem is that there are 3 lines that need repairs from getting whacked with a spade shovel or something, but I've cut out the small sections as I normally would, and normally I'd stick in a 3/4" male/male adapter with a couple hose clamps, at least that's what I've always done in the past. The problem is, the 3/4" adapters just don't fit properly, they're just a tiny bit loose, which is causing them to still leak a little, I've tried gluing them in with no luck, yet the pipe seems to be about the exact same size that you'd find in Home Depot (3/4"), is it a thin wall pipe or something? What is the best way to patch these up and have a long lasting repair that I won't have to worry about, of course short of replacing the entire lines?...lol Any help would be greatly appreciated...
Thank you fellas....
