Has anyone ever seen a 3/8" Female Compression - 1/2 Male Pipe Adapter ?
Chefwong
District of Columbia
I've checked quite a bit of supply shops around my way and no one seems to carry it. One shop has multiple locations in my area and they advised me that X store showed they had another location had it in stock.
So I head on down and the guys tells me no......
Argh....
Chefwong
BTW...it must exisits somewhere. If anyone has them and don't mind shipping some...I wouldn't mind getting a couple.
I know 3/8 compression female adapters don't seem so common but for example, I have a couple of 3/8 compress female to 1/4 compression male I picked up awhile back.
Master Plumber Mark
www.weilhammerplumbing.com
yes they exist
I keep some in my truck 3 or 4 of them
probably have 50 thousand miles on them already
just driveing around with me.....
They are very handy for those
"special combat situations" you can find yourself
in every so often..usually at 6 in the evening.......
they can be very very handy when you are about
to break down in tears..... ( I do that every so often)
In our town they can be picked up by the
handful at ECONOMY PLUMBING CO 317-264-2240
that place has all sorts of bastart brass compression
fittings you never need very often
Chefwong
Ha. Good Read. Thanks for the numba
Call me old school but I'm just not comfortable with compression fittings...over long term. It's for a DW hookup and the water feed has a 3/4 module that goes to the feed side. I'd rather stay threaded for the setup of I can.
fitting
The only fittings I have ever seen that go onto a compression thread were specialized, and few were intended for anything other than a low pressure usage. Even a compression cap will not always seal tight without a washer inside it, which would block your adapter. Why can't you remove the compression fitting and replace it with a threaded one?
Chefwong
Compression angle stop is soldered on.
I'll take a pic but it it's copper tee from the cabinet wall. Top has angle stop for sink. Bottom has another angle stop which was meant for the DW.
I currently have a 3/8 compression x 3/4" male adapter via small tubing hooked up to the angle stop. I'm just not a fan of doing a compression fitting....more chances of leaking down the road down versus a threaded setup IMO.
fitting
Screwing a fitting onto a compression thread has a lot more chance of leaking than using a conventional connection, unless the fitting has a ground joint nosepiece like the Brasscraft Add-a-Tees
Mikey
Hansville, Washington
Back to the original question -- Lowe's carries them
I forgot how much they are, maybe $2 or so. It's on the big display of brass fittings, Watts part no. A-124.
fitting
You did not read the original posting correctly. The A-124 is a conventional 1/2" fip by 3/8" compression fitting. It screws onto a pipe and then the copper is inserted into the compression side. He wants a fitting to screw onto an existing 3/8 compression thread and then convert it to ips size, male or female.
Mikey
The thing I had in my hand had a 1/2" male thread on one end, 3/8 compression fitting on the other, but I see what you mean (and what he needs). It wouldn't be a tough thing to fabricate, but I'm not sure how you'd seal the 3/8" end, if all he had was the 3/8 male thread. If it's truly a compression fitting, just fit in a short piece of 3/8 copper -- getting the other end to 1/2" is easy.
fitting
He doesn't want the compression ring and ferrule, otherwise he could run 3/8 copper all the way.
Chefwong
I wanted to test your post about leaking...
FWIW, my KA fridge has a 1/4 tube on it already. I am using one of those 3/8 female compression to 1/4" tube adapters and have the tube connected to the adapters with no leaking whatsover. I do have pipe dope on the adapter threads and also the 1/4" thread as well.
I picked up a 3/8" compression cap. Unless I'm doing something wrong...there is no washer, etc required under the cap. I put pipe dope on the angle stop and then the compression cap. Turned on the water feed and it did *drip drip drip*.
So I guess compression fitting it is ;-) So far, it's been leak free ....just not comfortable with a compression fitting as opposed to threaded.
Are We Good
Brooklyn, New York 11216
Argh....
Check this out on Amazon
LASCO 17-6837 3/8-Inch Compression by 1/2-Inch Male Pipe Thread Brass Adapter https://a.co/d/dyGk3eF
