Chris Fox
Hello, back from a 4-5 year hiatus on home projects.
Stating a bathroom remodel, remove tub add shower, move toilet and tiling walls/floors.
I am adding a fixed glass partition between toilet and shower head, so reaching in to the shower to turn on getting it was suggested to move the valve to long wall. I will be using PEX but would like to get suggestions n how to run PEX through the 2x6 and the corner wall using corner rounds etc..?
Not sure yet these studs are load bearing. The bath wall runs down the center of the home at the high pitch of the roof. Is there an option with out chipping away on the edge of the stud. One thought I had was to feed without corner rounds and feed a tool through the 1/2" gap to flex back into the perpendicular stud. The 2x6 should give enough radius to avoid hose kink?
thanks in advance
thanks in advance
