Grout in shower drain (ABS)
Feather
Calgary, AB
Does anyone know of a safe solution/way to remove grout from ABS pipe?
The tiler washed grout down a shower drain and now we have a major blockage. So far the only solution appears to be to cut out the affected section of pipe. Not my first choice as it means breaking up the tile floor, part way up the walls and having to retile the whole thing!
I don't know of anything that removes tile grout that doesn't hurt the pipes too. I have no idea why tile setters dump bits of tile, grout and mortar down plumbing drains. That is totally unacceptable building practice, and the tile setter will need to fix this. You had a perfectly working plumbing system, until the tile setter got lazy and decided to cement the drain shut.
All he had to do, was walk outside, and clean his tools there.
I had one job where the tile setter had dumped broken tiles down the toilet drain. I wondered if that was sabotage to the homeowner or just old fashioned ignorance.
Gary Swart
Yakima, WA
You use grout on tile because it is basically unaffected by water, so once it sets, water isn't going to remove it. Go after the tile setter, make him pay for the job. As Terry says, this is unacceptable building practice and a professional tile setter knows better. Or if he doesn't know better now, he will after he or his company pays the plumbing bill!
index.php
JohnfrWhipple
BATHROOM DESIGN & BUILD
North Vancouver, BC
Tile Guy dumped grout down drain.
Like the boys said. Not Good.
It takes little effort to plug the drain and keep the grout out of your homes system. Dumping grout down the drain and leaving it is horrible and shows no respect for a clients home.
If a small amount where to drop in and the grout was still wet a long washout with cold or hot water would convert the grout to sand and wash away the portland cement. Removing sand from a PTrap is hard to do and replacing the PTrap is the best approach.
As sad as it seems this is a common practice and one that can be avoided if the test plug is kept in until the tile job is finished.
JW
Feather
Calgary, AB
Thanks guys. There was a plug - but apparently it was easily removed. I guess we're demo-ing the shower!
I used muriatic acid to open a drain like that. You have to "suck it out" and put in fresh acid as it gets "exhausted". I had one 3" sewer line through a house that was completely filled with grout for about 20'. That had to be cut out and replaced.
Hairyhosebib
Arizona
I actually agree with Yoda. LOL TILE GUYS DON"T GIVE A CRAP UNTIL IT HAPPENS IN THEIR HOUSE!!It would be great if a short masonry bit attachment could be put on the end of a sewer machine cable and it would just drill a hole through it.
ResPlumber
Michigan
I have had success only one time getting grout of a shower drain. I was able to chip it out using a long screwdriver, shop vac with the little hose and a snake. I would chip down as far as I could with the screwdriver then suck out the pieces with the shop vac to get where I could not with the screwdriver I used the snake to bang and loosen up the grout then suck it out it took a while but I was lucky and it ended up working.
Usually it flows around the bottom of the trap and fills the entire "U" bend, then you cannot get to the section between the bottom of the "U" and the outlet.
KateCreative
Toronto
Is muriatic acid safe on all drains? My tiler washed all the chunks of grout down the drain and into the shower trap.
Now it's backed up. Trying to avoid breaking through the ceiling in the unit below me to get at it. Plumber has an industrial
snake and shop vac to try. But the acid sounds helpful if it's okay on the metal pipes.
MACPLUMB
HOUSTON, TEXAS
Muriatic acid causes Noxious Fumes and cannot run a snake down after it has been used, because will ruin the snake and burn the Plumber
Sylvan
Still learning
New York
Over the past decades I found this is what tile installers do with total disregard for the drainage system.
So having faced this delima over the past 4 decades I decided to make my own grout/ cement breaker tool :)
I took a piece of 1/8" steel welded some small chain onto it drilled a hole in the steel so it would fit in the female end of a snake and SLOWLY allowed the chains to knock loose the grouting and then use a decent wet dry to remove the debris so it doesn't go past the trap
Again slowly feed the snake in allowing the chain to knock the gouting lose
Tbenton
Virginia
Terry, Can't blame our grout clogged shower drain on a contractor...my husband did it. He swears he put a towel over the drain in the fiberglass pan in our small stand alone bedroom bathroom shower on second floor BUT yet enough got down there somehow and its blocked. I took the first shower in it yesterday and the pan filled up pretty quickly and almost overflowed and I take fast showers! I stuck a metal rod thru the holes in the drain cap and hit solid stuff a few inches down. It finally drained after many hour but now what? We have septic tank and no windows in the small bathroom so don't want to use acid. Would any of the concrete dissolvers on the market do the trick? I also read about CLR but I use it for toilets when we get crusty stuff from our alkaline water in there but can't imagine it getting thru that hard portland cement grout. I fear that trying to chip at it and vacuuming it out or use a chopper type auger (General Pipe Cleaners 1CG 1" ClogChopper) might send it down further and cause more blockage we could never get to. The only one saving grace may be that the shower pan and PVC piping can be seen in the laundry room ceiling but its near the furnace/ big duct work and looks really hard to get to. He is more than willing and capable to cut out the blocked PVC and put in new one but if he can't get to it??? Thats why I am asking if any of those concrete dissolving liquids might turn the hardened grout mushy enough to force it thru all the PVC and outside and not make more trouble? You have helped me in the past so here I am again. Thanks in advance, Terri
Pipemagic20
Australia
A safe solution that will not damage the pipe is to use a product called Croc Crete from Pipe Magic.
The process is, if there is any water or gunk in the pipe at present, this will need to be removed using a wet-vac, or dragging rags through the line etc.
After this is done, you then poor the Croc Crete solution into the pipe. The Croc Crete solution requires to remain in contact with the grout for a 12-24hr period. This will dissolve and soften the grout and allow to easily flush or remove from the drain.
Pipe Magic have a number of videos on the Croc Crete product, they also supply pipe relining supplies.
Ryan
