Ruralist
Stay with me--its a somewhat hard question to setup correctly. The question is given both before and after additional information.
Question: Will the installation of a flow check valve in the mechanical room between the cold water supply from a 100 gallon hydro-tank and the addition of a properly sized thermal expansion tank reduce heat driven pressure fluctuations better or faster than relying on the heat-pressure adsorption back at the hydro-tank some 150 feet away? Will the thermal expansion tank sitting directly off the hot water heater's cold supply just work better and prevent pressure flexing of system components either up or down stream of the hot water heater?
This forum seems to be the place to get answers not found readily from other resources. I have read many of the threads here concerning the "need" for a thermal expansion tank(ET) in closed systems and/or whether an open system would benefit from an ET. I also understand the situations where backflow prevention devices of several types may be required from a municipal system. I am not connected to a municipal system. I have also found several somewhat different but mostly similar definitions of "Open" and Closed" system. I pose a few questions here to gain more insight and decide if I should install a thermal expansion tank in the configuration I have for added safety and/or reducing stress-flexing the pipes and fittings down and/or upstream of the hot water heater.
Configuration:
Potable Supply (cold): Groundwater well with submersible pump delivering 3 to 5 gallons per minute into a 100 gallon bladder hydro-tank with a static operating pressure around 40 psi. Flow check valve on supply side of hydro-tank prevents water from returning to submersible pump or its supply line.
Hot Water Heater: Gas fired condensing high-efficiency hot water heater which will be set higher than 120 degrees F with thermostatic mixing valve for domestic hot water. A flow check valve on the cold supply to mixing valve is proposed to prevent migration of hot water there. The hot water heater will also be used for some space heating through a heat exchanger and a closed-loop hydronic system. No questions regarding the hydronic system, a thermal expansion tank is required in this typical closed-loop system. The groundwater source and hydro-tank configuration seems to be an "open" system as long as there is no backflow prevention between the hydro-tank and the hot water heater. The pressure and temperature ratings of the hot water heater and hydro-tank differ to some degree and could play a role in what is best.
Configuration:
