BenWara
This might be a silly question but I've search and can't find an answer. I started finishing my basement. It was roughed for a bath by the builder. I read in a magazine the other day that sometimes the builder won't glue down the pipe for the stool so you can take it out and trim it easily. I wondered if mine was not glued. Sure enough it wasn't. So i wiggled it out and some of the gravel that was under the slab fell in the drain line. I picked most of it out then I stuck my shop vac house down it to pull what else i could out.
I'm not certain I got 100% of it. If there is any around the elbow it isn't much. maybe 10 pieces at the very most that aren't packed together. The gravel is about the size of three kernels of popped pop corn each. Is this going to be a problem?
also now when the pipe is in there there will be void around it from the gravel that fell loose. should i worry about that? it won't be very big. maybe less than one inch.
thanks
thanks
