Anthony W
We have a private well with a submersible pump and an 80 gallon pressure tank. If our power goes out when the pressure tank is full, it can supply enough water to flush our toilets many times or have running water to cook or wash up. Unfortunately, it always seems like the pressure tank is near it's minimum level when our power goes out, leaving us only enough water for one or two flushes.
So, I'm investigating options for having at least enough water to get us through a day with minimal usage (no laundry, showers, etc.) during power outages. Most of our power outages last less than 12 hours, so I don't really need a long term supply of water. We have a wood stove for heat and backup battery supplies for lighting/entertainment.
Right now I keep a couple of 5 gallon containers full of water in our pump house with a couple drops of bleach in each. I filled them up mostly to have water for flushing toilets, but we're getting older and carrying 5 gallons of water down to the house and pouring it in the toilet tank isn't very user friendly. Especially if it's icy and dark during a power outage in the winter. I also wouldn't feel comfortable drinking stored water that may be a few years old. I filled them up a few years ago and so far it hasn't been worth the trouble to haul them in when the power has gone out. We don't really have any place in the house to keep the 5 gallon containers.
I could get a generator for the pump, but again it's not very user friendly on a cold winter night in the dark. Not to mention having to store the generator, fighting to get it started, or worring about fuel going bad.
A battery backup system would be nice, but finding a system large enough to support our 1/2 HP 240V pump for a day would be cost prohibitive.
I thought about adding a second pressure tank, but unless I'm missing something, we could still end up in the situation where both tanks could be near empty when the power goes out. I would need a way to ensure one tank is always full, and I'm not sure that is possible.
Another option is to add a storage tank in the pump house, and add a second booster pump. Unfortunately, that would add a lot of cost and complexity to an otherwise simple system.
I also thought about adding a storage tank in our attic space above our bathroom, and plumb it in just to feed the toilet from gravity. But, I would be limited to a tank that could fit through the attic opening, would need to redo some plumbing in the house, and would have to add a pan and drain in case the tank leaked. It's simpler mechanically, but a lot more work to install.
Is there a simple way to supply our well water during short term power outages?
