Gerber faucet stem replacement
AlanP64
Fort Worth Tx
Ok, I’m sure this sort of thing gets asked quite a bit, I apologize for adding another one. My house was built in 1955. We have a full bath with tub and shower, then a small bath with just the shower only. In that shower, with the hot water faucet closed, when you open the cold water, water will leak around the stem and the handle. I will attach the pictures that I believe y’all typically ask for. The handle insert indicating hot or cold have the Gerber name, so I’m assuming these are Gerber. This shower isn’t used very often, so I’d like to just replace the stem assemblies or rebuild them if I can’t get replacements. So, that’s basically my question.. Where can I possibly find replacements? Thanks in advance
AlanP64
Fort Worth Tx
Ok, I thought I was done but one more question. Anyone know where I can find one of these or a proper substitute? I’ve found one place online and looking at the reviews, it appears it’s not a very reliable place to buy things.
AlanP64
Fort Worth Tx
Doesn't appear to be in stock there. I had looked at Faucetshark.com but they have a ton of negative reviews, "No ship after paying for parts. Not answering phone etc."
Dj2
California
You need a rubber washer under the screw, you also need a nylon washer at the bottom of the thread going into the faucet body.
If you still have a leak, see if you can get the seat out of the body and replace it too.
You might have luck finding parts at a local plumbing supply stores, not the big stores. Take the stem with you.
If not, you will be much happier with replacing the faucet.
AlanP64
Fort Worth Tx
Correct, I bought the components to rebuild them. The hot water side, is the big problem. the threaded nipple that goes over the stem and the trim piece on the outside screws to that (can't spell the real name) has sheered off inside the bonnet or body of the stem piece. I have tried extractors and everything I can think of but can't budge it. I would definitely be a better off with a whole new faucet, but obviously that means tearing out the wall in the bedroom side. Not real jazzed about that idea but might wind up at that point. This shower was rarely used, just my wife and I at the house. So, we typically used the big bathroom facilities. She has MS and is a bit mobility impaired. She uses a transfer bench in the big tub/shower and I hate having to move it in and out to use that tub/shower myself. So, I have a big interest in getting this stand up shower fixed.
AlanP64
Fort Worth Tx
If you are not trying to keep the period look you can install a modern kit to completely rebuild and trim. Search "Gerber RK1830-2"
Thanks. I did find a solution. After 3 different ACE hardware stores, I wound up at Elliot's in Dallas. They suggested Lasco S-1047-3 and they had the threaded nipple pieces. Installed and working. I appreciate everyone's suggestions and help.
Weary_landlord
Illinois
Did you ever confirm these were actually Gerber? This is the only thing on the entire web that comes close to what I have.
amazon , order it, get it , try it out is one super easy way to find out. Illinois probebly has a good hardware store to walk in if you prefer. Thats the 2 ways I do it or ask on here (already done)
