gas stove/range question.
Randyj
Alabama
I'm working on a counter top & sink replacement job. The customer asked if I knew how to turn down the gas going to his stove. It is about 9 years old and a cheap sears product ... has a digital clock for what that's worth. I know nothing about these but can clean them up and make them work okay. I have no idea what to do for a stove that's getting "too much" gas. Any help here?
Gary Swart
Yakima, WA
First of all, you're not qualified to work on gas appliances, and if you did work on the stove and later if there was any problems, you'd be on the hook. Second, the gas into any gas appliance is regulated by the applance controls, not the supply line and/or the cut off valve. In other words, there is no such thing as a gas appliance getting too much gas. Don't touch it.
stove
There is no such thing as an appliance "getting" too much gas, but it can "use" too much gas. For that condition the burner orifices have to be modified or adjusted. DO NOT touch them unless you know exactly what you are doing, because you can create an unsafe condition if you mess it up.
Randyj
Alabama
Yes... the home has propane. I questioned him about the orifice being appropriate to be sure he doesn't have the orifice for natural gas. I have already told him..."the simple solution is simply not to turn it as high as it will go." I'll be back there this weekend to plumb the replacement sinks and will refer him to his propane supplier... they will be equipped to handle it and can check the line pressure and regulator.
Randyj
Alabama
Yeppers... I've seen people drive a nail thru them to open them up more. I've had to clean quite a few but in general do not mess with gas. My eyesight is too bad and I need magnifiers and very good light to tell if they have any obstruction, but that is opposite of the problem this guy is having. I did suggest that he may need a smaller orifice.
Randyj
Alabama
Gary...not trying to be a smart butt here...but to be qualified (not necessarily "legal")... you only have to know what you're doing... I've seen plenty of bad truck drivers with a CDL and plumbers who couldn't plumb or fix diddly who have plumbers cards....and a whole bunch of those who think they're worth $200 per hour and I would rather pay them to stay away from my job than to be on the job. When messing with gas...well, it's kinda like being a crop duster pilot..there's good ones and dead ones...no in between.
Verdeboy
Is the problem that the gas-to-air mixture needs adjusting because it is burning too rich? Or is the flame just too high even when the knobs are set to the lowest position?
Cass
It sounds like you have a natural gas unit that needs to have the oriface changed, but no way to tell for sure from here.
Randyj
Alabama
It's not the air/gas mixture, has blue flame,not yellow and not smoking, It just has too much fire. I've seen what happens with a water heater on propane that has natural gas orifice...waaaayyyyy too much flame. That really could be his problem. I'm gonna refer him to his propane dealer.
Verdeboy
What happens when you turn the pressure regulator on the tank down? What does the pressure regulator read now?
Alternety
Like an engineer
Washington
The range will have specs for max/min pressure. Any other gas devices (e.g. boiler, water heater) on the tank will also have limits. They are probably specified in inches of water.
If you can find any information plate on the unit that has this information or if there is a manual available, you will then be able to check pressure at the propane regulator and correct the pressure if necessary. This will affect all the other devices using the propane tank.
You really ought to let the dealer handle it; as you have said.
Randyj
Alabama
Thanks. If he wants me to take a deeper look at it I will. I do have a little knowledge of working with gas and a little with stoves. Just knowing what to look for is the big thing...and not being stupid. Bad thing about gas is that it is heavier than air and can collect on the floor where it can blow your house up... actually seen that happen before....very strange sight.
Cass
Propane is heavier than air and will pool, but natural gas is not.
flame
An orifice that is not adjusted or drilled to the right size will cause a burner problem regardless of whether the gas pressure is too low, correct, or too high.
Randyj
Alabama
Thanks Cass... a small point that is important there.
I have to do the final hook up tomorrow...the granite guys who installed the counter tops did a botched up job but it will pass. I got the homeowner to demonstrate the stove problem to me. It's not the gas or the amount of gas. I think it's just a cheap stove and if anything is in the valves. I'm sure that someone who knows more about stoves would know how to correct it. It gives a decent flame. IMHO it is not as hot as it should be nor does the flame turn down low as it should. His complaint is that there is hardly any middle ground and most of the time it's either too hot or it shuts off. It will boil water at about any setting and if turned any lower it shuts off. Anyone got a clue?
Cass
If it is new then bring it back or have it serviced on site by the Mfg.
