Garbage disposers
betsycapp
Does anyone have advice about these? Would use for soft garbage only, relatively light use. Which are best?
Redwood
Terry said everything that needs to be said! :D
Go with his advice and have no regrets!
SteveW
DIY Senior Member
Omaha, NE
Sounds like you are trying to make a case for buying a cheap disposer. I'd follow Terry's advice, especially if you plan to stay in your house more than a few years. Cheap disposers rust out relatively quickly, and don't grind as well.
For what it's worth, I put an Insinkerator Evolution Excel, their top of the line model, in my kitchen a few months ago and am glad I finally broke down and spent the money. It is really quiet, doesn't clog if you put potato peels in it, and should last a long time.
disposers
One of the major differences between disposers is the way they mount to the sink. The majority of them other than ISE use a plastic mount and they often loosen up and leak.
Dunbar Plumbing
www.KoldBreeze.com
www.pmmag.com
Look at the video at the bottom.
So easy a caveman can do it.
We are now in the design of "belt-buckling and ferno'n" our plumbing systems together because someone thought glueing a fernco to a sink is a good idea.
Mario
Kansas
Like Terry said; "the Insinkerator Evolution's are great"...they are the model 777's 1 h.p. modern equivalent.
The new top of the line model will auto reverse and go into hammer-drill mode when put into a bind.
A little pricey though. But worth every penny. I'd put one in my house if I had to have the best.
If you're looking for a cheap unit at a good price, Emerson sells a "badger 5" clone that looks identical to the Insinkerator 1/2 h.p.
It is said to be made on the same assembly lines and sells for about $70 wholesale.
disposer
A typical engineer's video. Did you notice he is installing it with the sink on the countertop, UPSIDE DOWN? I would like to see him do it inside a sink cabinet, holding the disposer in place while snapping the clamp with both hands and apparently having a hard time doing it.
