Flushmate in Gerber water level needs adjustment
l123
PA
I have Flushmaster model 503 in Gerber toilet. I have 2 problems:
(1) The level of the water in the bowl is too high - I could use and 1" or 1.5" less water.
(2) There always is some water (say <1/4") in the bottom of the ceramic tank where the black lushmaster is installed).
How to adjust the water level?
Thanx:confused:
There is no adjustment for bowl water level height. It's determined by the top bend on the trapway which acts as a dam.
The water in the tank is normal.
The height of the water in the bowl is a design thing...nothing you can do about it. If you could lower it, it may not flush right. The bowl is almost always filled up to the limit so it can work right. If you want a toilet with a lower water level, you'll have to replace the toilet. As to water in the tank, not sure about the flush mechinism in that toilet...if it uses a flapper valve, it's normal to not use all of the water. If it isn't, something might be leaking.
Gary Swart
Yakima, WA
The weir in trap determines the height of the water spot. Low flow toilets rely on gravity to produce the pressure with the small volume of water used to flush. They are designed to have more water in the tank than is used during the flush. The extra height provide a bit more pressure. You can cheat a bit if you think you need more water on a particularly heavy load by just holding the handle down for a couple of seconds. A normal flush just requires the handle to be pushed down and released.
newb
PA
Wrong answers
There is something wrong with all the answers.
If those answers were true it would mean that Sloan Flushmate is not using 1.6 gal/flush but it factually is using the content of the black tank, i.e. about 1.6 gal plus the content of the bowl, i.e. about 2.5 gal for the total of 4.1 gal/flush.
On the other hand if the FLushmate relies on the height of the bend in the siphon, it would mean that (a) there would be a lot of water wasted while overflowing the siphon until Flushmate shuts the supply to the bowl - both are unrelated; (b) the hight of the siphon is not the same in all toilets resulting in different levels of water.
I have tried Gerber standard height and ADA height - both have the water level less than 4" from the rim - result is that all men using these toilets complain about having their balls dunked in the dirty water.
Something is very wrong with this picture and the 7 men who complaind cannot be the only one in the world.
It is obvious that the water will flow into the bowl until the Flushmate shuts off the supply. This timing must be set at the factory by the shape and size of various Flusmate components - ergo they must be capable of modofication or Sloan Flusmate should modify them.
The only question is how.
And the correct answer is not: 'it is impossible', but rather the correct answer is collectively: "we do not know".
So now it is Sloan Flushmate time to answer.
Gary Swart
Yakima, WA
Yes, the water will continue to flow into the bowl until the supply is shut off, but the height of the water in the bowl will not change unless the toilet is clogged. The extra water just goes down the drain. That why if you have a flapper that doesn't shut, the water continues to flow into the bowl but does not overflow.
Jimbo
San Diego, CA
ALL toilets are designed to have the water level right at the weir of the trapway. In terms of actual water level in the bowl, also called 'water spot' there are different designs. Most folks complain about toilets with a low water spot, but sometimes the issue about 'low hanging fruit' also results in complaints.
Bottom line about your toilet, if you somehow lowered the water level, it would flush poorly.
newb
PA
Thans to all.
You made two points: (1) water will waste through the siphon until the FLushmate shuts off the water flow into the bowl - but of course this is not accceptable way of wasting water in todays toilets. (2) if the water level in the bowl is lowered it may flush less effectively or at the extreme it will very poor and require double flush - also very wastful - but acceptable if it eliminates involuntary ball-washing.
There is nothing worst than having the balls washed in the bowl water - let's waste the water in double flushes.
Obviously it is the Flushmate valve that shuts off the water flow into the bowl.
Can some modification be made to speed up that shut-off time? Or is it the case that the bowl flow and the pressurization of the holding tank occure at the same time - which would mean that no reasonable mod can be made?
If it is totally unmodifiable - we will have to junk all the Flushmate Gerber toilets and buy something with water level at 6" 9or more) below the rim.
By the way - why manufacturers do not list the rim-water level distance?
Anyone has any recommendation of efficient/effective toilets but with the low water level. We do prefer bidet for washing.
Thanks again.
As far as I know, the Flushmate is not adjustable. And, if you need a lower water spot, you'll need to get a new toilet as it just won't work right. It has nothing to do with the Flushmate, it is the toilet bowl design. As noted earlier, ALL toilets are designed to be at their 'overflow' height. If they aren't, they frequently flush poorly, if at all, on the first try. A taller toilet, such as one in ADA configuration would likely have more room between the seat and the water spot, plus, is more comfortable for most people as they age.
newb
PA
Thank you - I do appreciate your advise. Indeed we had the standard height Gerber with 28-380 Flushmate tank, and hoped that going into ADA height would solve the problem. Unfortunatly it did not, the distance was the same - which means, taking your explanation into account, that Gerber must have made the siphon taller in ADA toilet.
I guess time to dump it all together and get something else.
Also, as the FYI I just learnedfrom the fellow at Flushmate that " the codes and standards applicable to toilets
manufactured or sold in the US and Canada require a minimum 2" trap-seal.
The trap-seal is measured from the top of the trap (where the waste exits
the bowl) to the surface of the water. Depending on the geometry and design
of the bowl, the water level could be anywhere from 4" to 8" "from the rim
I guess I want the 8" - who makes it?
Radford
Fort Worth, Texas
Newb.
I'm a "newb" on the forum also and I have the exact same problem you have described.
(I'm not exactly a newb age wise at 89 and a Navy veteran of WWII.)
My old toilet was an Eljer old style flush which was in perfect order. We had to have extensive plumbing repair including the replacement of 50 year old cast iron pipe under the bathroom which required a 4 ft. by 10 ft. tunnel under the bathroom. As part of the package we opted to replace the excellent working handicap height Eljer with adequate water level clearance for my equipment with anew Gerber Avalanche at the bloated price of $650! The Gerber is not as tall and the water level is only 5.5 in from the rim which gives me a complete dunking. I have complained to my plumber which is Ben Franklin Plumbing and a plumber is to come out tomorrow. So far I feel ripped off and am totally frustrated with the whole ##%^& situation!
Newb, I appreciate your attempting to teach plumbers who have been doing this for many years, 60+ in my case, HOW to do their jobs. But maybe you should get some experience first. Sloan ONLY determines the amount of water for the flush, the toilet manufacturer determines the water surface area and the water height in the bowl. Since the water "level" is restored after the flush, the "net amount" of water used is the 1.6 gallons from the tank.
You might be able to work around this problem with a thicker seat.
Patrick Questel
New York
Never mind the family jewels hanging in the water. I have another problem - water is too low. I just had installed an elongated Gerber toilet with Flushmate. The water in bowl is too low because now when I urinate, the stream hits the dry part of bowl and splashes a bit. Sometimes, stream is not strong enough to aim. I have to straddle the front, to make the stream hit the water and have no splash.
Gerber needs to let us adjust the water level or redesign shape of tank.
SOUTHSIDER
Chicago
I'm having a problem with mine also. The water doesn't flush everything the first time. Takes 2-3 more. If there is no adjustment this means the unit is malfunctioning. Am I correct? And no adjustment means no repair and it needs to be replaced. Or is it a replacement part to correct this.
They are repairable. The Flushmate site has instructions for tuning them up.
