Hello,
Thank you so much to the experts on this forum answering newbie's questions as they have taught me more than any other resource so far.
I have recently installed a new Fleck 9100SXT Twin Tank "96k" grain system in my home set up with well water. It has been operating for the past 4 months providing me with very soft water. A bit salty but soft (I'm the only one who notices). I have a family of 5: 2 adults, 2 toddlers, and 1 infant. However, I have the following issues that I was hoping you experts can help me fix:
1.) Loss of resin in drain. My water softener drains into my sump pump. I have noticed resin beads accumulating in my yard where my sump pump drains out. I shined a flashlight on my tanks as suggested by "BannerMan" in another thread and I noticed both tanks have a resin level that is only about half way up the tank. When I ordered my system, I did not elect to order a "Upper Basket". I am thinking it was a mistake. Why am I losing so much resin? My DLFC is stated to be 2.4 gallons per minute. My well supplies water to my house via a 3/4" copper pipe. I used 1" PEX tubing to route that through a whole house water filter and then to a stainless bypass valve on the water softener. Is this too much flow blowing out my resin?
2.) Regens happen during the day instead of 2:00am and cause a noticeable loss of water pressure. Would rather deal with a little hard water than be taking a shower and the flow slows to a trickle!
3.) Excessive salt consumption. I used my water suppliers settings and I am consuming way too much salt. I think my Brine Flow is too high based on my calculations, again thank you "BannerMan" for helping somebody in another thread.
Advertised capacity: 96k total grains, Twin 48grain, 1.5cu ft3 tanks
Stated capacity in the manual: 30,000 grains
Current Programmed Settings:
DF GAL
VT dF1b
CT FI
NT ---2
TS U1
C 24 (Should this be 36 like BannerMan said in another thread? Or 30 to match my manual's capacity?)
H 28 (I have a hardness of about 27 grains per gallon per my water test below)
BW 10
BD 50
RR 6
BF 9
FM P0.7
BLFC 1.5 gpm
DLFC 2.4 gpm
Here are my back of the envelop calculations:
If my system is taking 9 minutes to fill the brine, and my BLFC is 1.5gpm, that is 13.5 gal per brine fill. 3lbs per salt per 1 gal of brine = 40.5lbs salt per regeneration. That is a huge amount of salt that I am using. Should I reduce my BF down to 3, which would give me around 13.5 lbs of salt per regen?
Here is my water testing results just for added info:
Total hardness: 457 mg/ml
Calcium hardness: 278 mg/ml
Magnesium hardness: 179 mg/ml
TDS: 588 mg/ml
Chloride: 108 mg/ml
Sulfate 20.3 mg/ml
Nitrate: 6.050 mg/ml
Nitrite: ND
Arsenic: < 0.003 mg/ml
Iron: < 0.025 mg/ml
Lead: < 0.003 mg/ml
VOC: ND
Coliform Bacteria: ND
Please let me know if you guys have any suggestions.
Thank you
DF GAL
VT dF1b
CT FI
NT ---2
TS U1
BW 10
BD 50
RR 6
BF 9
FM P0.7
BLFC 1.5 gpm
DLFC 2.4 gpm
TDS: 588 mg/ml
Chloride: 108 mg/ml
Sulfate 20.3 mg/ml
Nitrite: ND
Iron: < 0.025 mg/ml
Lead: < 0.003 mg/ml
VOC: ND
Thank you
