My Fleck 5600 injector drain assembly managed to develop a leak from a crack and needed to be replaced. I ordered the unit below and installed it today.
The label on this piece says Injector 1, my old piece says Injector 0. I'm guessing I ordered the wrong part since I'm getting constant water pressure to the brine tank even after it's done regenerating. VT is set to df1b. Do I need to order a different part number or can I swap something from my old assembly to make this work?
Fleck Injector/ Drain Module for the 5600 Valve (60084-01)
Fleck Injector/ Drain Module for the 5600 Valve. 2.4 GPM DLFC. .50 GPM BLFC
www.water-softeners-filters.com
