SunburnedinAZ
I could really use some input on options for this replacement or repair. I have some DIY experience on wood subfloor/cast iron flanges but as a new homeowner this combination is not one I am familiar with.
I moved a toilet out of the master bath to do some flooring. The existing floor is thin self-adhesive vinyl floor tiles.
The existing flange appears to ABS with an older steel ring that had crumbled away. The drain pipe is 3" ABS and I think the flange is 4" bonded to the outside. The old steel ring was not secured to the concrete in any way. So once bolted to the toilet, any movement by the toilet would have put the weight into the ABS lip of the flange. I am not sure of that was a common practice but I could certainly replicate it with a replacement ring. The flange sits up about about 3/8 to a 1/2 inch on each sides and is not level front to back.
Any help would be very appreciated.
- If I use a stainless steel replacement ring to fit around the old flange, should I leave it unsecured as it had been or secure it to the slab and leave the flange funnel raised up over it?
- Or should I try and cut away the existing flange and replace it with a different outer mount that sits lower (on the new flooring)?
