If, after you clean it off, it is thin or fragile, or has parts totally rusted away, you need to do something to it - probably replace. If it is solid, and you get a good seal with the wax, it could last another 50-years. See if one of the plumbers responds - I'd take their experience...but, CI works, is quiet, and can last a very long time. Under marginal conditions, it might also fail in a decade or two as well. Terry has indicated when people don't flush overnight (probably because of the noise), that the urine, being heavier than water, can partially drain, nearly undiluted. He's shown pictures of the bottom of the pipe literally eaten away. If the pipe is solid and the flange is solid, it should be okay. The only other issue is the height of the flange once you get the new floor installed. Ideally, the flange would be on top of the finished floor, but as long as it isn't recessed too far, it can usually be dealt with.
