Evidence Of A Broken Sewer Line
Majus
Oklahoma
Heavy clay soil, likely PVC sewer line going to the main. Large metro area, but on the periphery of many small earthquakes per year due to fracking (Oklahoma). Water standing in small pools on the surface in an overall area of about twelve feet in diameter. Is this evidence of a broken or disconnected sewer line?
I don't think so -- depending on what you mean by evidence.
A more likely theory would be a leaky water pipe, I think.
If there is an outside cleanout, look down the hole. Is water standing? If not, I don't think a leak from a feared hole could cause surface water. Standing water would call for further investigation.
No outside cleanout? Is this your house? Basement? Overhead sewers? Is there high ground water causing leakage into basements in your area or causing your area to not have basements?
Is the wet area on the street side of the water meter or the house side? If the house side, I would think checking for a water leak would be your priority.
Majus
Oklahoma
No water lines of any kind near the area of the standing water, only a large storm drain and the sanitary sewer main. These are all at the rear of the house; water lines are in the front.
The standing water is not mine, but is in a direct line with where the sewer line goes to a neighbor's house. I'm on the HOA Board which is why I am investigating it.
Gravity makes water go DOWN from a leak, so unless you have something in the house higher than the "pond" and something underground preventing the water from seeping downward, the "pond" is caused by a pressurized leak.
Majus
Oklahoma
The house sits about four feet higher than the ponding water on sloping ground. I figured if the clay soil got saturated it could cause ponding like I'm seeing. I'm going to speak with the homeowner today and warn him about it. Next week I will call the city water department and see if they will take a look at it.
Cleanout? Basement? Could this be water from a sump pump?
Is the homeowner part of your association?
Majus
Oklahoma
No cleanout, no basement, no sump pump. One of things I did was try to see any indication of pressurized flow but the surface is very still. The homeowner is part of our Association, and he is responsible for repairing his sewer line.
Widgit Maker
Alexandria, Virginia
But you don't know IF it is his sewer line or IF it is broken. All the responses you have received indicate that is is unlikely. First PVC is pretty strong and is flexible to some extent. It would not only have to be broken or ruptured but there would also have to be a blockage after the break. Storm sewer is more likely or possibly an underground spring..
Majus
Oklahoma
Underground spring is more likely. Not only is this area on top of an aquifer but I have been told it has underground water due to proximity to a very large lake (less than two city blocks east of me).
Majus
Oklahoma
There's enough of it there to detect an odor, and there isn't any. I will call the City on Monday and ask them to check it out.
