hj,
two bolts in rear. if what you say is true, every single one of these toilets sold and installed does not have the necessary tight seal. they must use a different system than the flange around the drain. europe always seems to be about 20 years ahead of us when it comes to style and technology in the home. as i said earlier, i have already successfully installed one a year and a half ago without any problem. the difference being, wood floor which allowed me to use regular double threaded johnny bolts. the other big difference was a 3" pvc sewer drain pipe. this allowed me to use a fernco waxless seal. i have to assume you are unfamiliar with this product. it comes with adhesive on it and you attach it to the bottom of toilet first, around the horn, then drop the fernco extension down into drain. ribs on fernco pop and lock into drain giving tight seal. can't say how long it will last but no leaks or sewer smell so far. seems like the future to me.
the center of the horn still measures 12" from back wall, like american toilets.
adding pics is something i haven't conquered with my chromebook as there is no hard drive.
mr. whipple,
i assume the decorative display of toilet paper was your idea? you sure did some beautiful work. love that compact toilet. why would using construction adhesive in this application be lame? if it is holding my cheap metal exterior threshold to concrete in sub-zero temps while being stepped on all day, every day, why wouldn't this hold up? toilet is one-piece, very heavy. floor level so there should be no rocking.
koa,
i am using something similar to bar stock and i have a guy welding 1/2" headless bolts to that which i plan to "epoxy" to the floor behind toilet. assuming it holds fast i now have bilts to fasten toilet to. the next problem is the rough cast iron drain pipe which may preclude me from using the fernco. i have seen some compression flanges while researching online and maybe i can get some advice here. i'm thinking if i can use one to reduce drain from 4" to 3" i will be all set. the flange isn't for providing bolts for the toilet, it will be for providing secure purchase for a fernco or something similar which would affix the the bottom of the toilet.
