Eljer LaSalle Whirlpool help!
JSarge
Gillette, WY
I have recently installed a Eljer LaSalle whirlpool tub and I have several questions.
1. I also purchased the in line heater for this tub....do I need to have two separate GFCI outlets (one for the tub pump and one for the heater)? Or can they both be plugged into one GFCI outlet?
2. After installation, I can not get the pump to turn on. I have reset breakers, messed with the jets, and tried everything I am comfortable doing. Is there anything else I can do or check?
Thank you!!
Rlbbahill
Thank you!!
What did you do about the circuit? Did you install an individual gfci for both or plug them into the same? I have the same setup and just used the tub for the first time tonight. Worked great till about 20 minutes in the circuit blew. Not the gfci.
Just curious what you did. I have two gfcis there but the other one is running an in wall fireplace/heater.
