Tyler Davis
- Messages
- 7
- Reaction score
- 0
- Points
- 0
I have a decent Amana refrigerator, freezer on the bottom. I have the copper water supply line coming out of the wall behind the fridge. I am planning on adding the Amana icemaker to the freezer compartment. There is a pre-drilled hole into the freezer compartment to run the flex tube through.
I want to add a Brita filter tank to the refrigerator compartment, but there is no hole through which to run a water supply tube. Can I drill through the back of the fridge to pass a tube through? Are there any condenser coils I risk hitting?
I would split the connection from the copper supply tube into two plastic flex tubes. The icemaker has its own shutoff mechanism which turns off water flow when the ice bucket fills up. I would use a manual shutoff valve right before the Brita jug to turn off water until you want to refill the jug
so what do you think? is this a sound idea?
