Pros,
I'm in the process of remodeling a guest bathroom and will be moving the toilet to the other side of the room and installing a tub in the old toilet location. Unfortunately I'm drawing a blank on a good way to do the DWV lines.
In the first picture below, the lavatory drain is on the left and the vent runs through the roof. The second picture is the lower section of the stack in the first picture. In the second picture you can see the old waste arm capped.
Can the tub connect to the toilet arm before it connects into the vertical tee? I'm trying to avoid tearing into the cast iron if I don't have to.
Thanks for any suggestions, much appreciated.
