Double Vanity Vent and Drain
Kathristin
I am remodeling a bathroom and am a little confused as to how to vent and drain my 60" double vanity. The existing 2" vent/drain is off to the left of the vanity. The attached picture shows what I inteded on doing. I am not that good with isometric drawing to fittings are labeled because I didn't know how to draw them. (This sketch is in no way to scale, the distance from the fixture tee to the 2" main drain is approx 3 feet)
Any input would be greatly appreciated!
dwv
That is one way. Or, you could do that for the right hand sink with the riser and tee right behind the sink, and use a tee in the main riser, at the correct height, with an arm with and elbow for the left hand sink. That would be my preference unless you also install a cleanout tee below the intersection of the double fixture fitting, (NOT a cross).
In Washington, you would need a 2" x 1.5" x 1.5" x 1.5" fixture cross.
The pipe leading down would be 2"
The vent could be 1.5"
Kathristin
Thanks. Are 1-1/2"x1-1/2"x1-1/4"x1-1/4" fixture tees available? I realized that I don't need a 1-1/4"x1-1/2" trap, it can stay 1-1/4" to the tee, then be 1-1/2" drain and vent.
According to NJ plumbing code, those sizes are acceptable. Lav is 1 dfu each and 1-1/2" can have up to 3 dfu.
NHmaster
S. Maine
You can get a 2,2,2 cross and bush down if you cant find one that reduces. Here you can't put anything smaller than 4" through the roof.
