Paul Spindy
While pulling up glued down engineered flooring, I had lots of damage to the cement slab. In most areas cement was also being pulled up.
What product would you recommend I use to repair the damage? Should I just hire or try to use floor level materials because of the amount of damage. The floor is level. I will be installing LVP 12m thick Cali flooring.
Thanks in advance.
Paul
Thanks in advance.
Paul
